Comware
  • 1.  540zl mgmt module crash
    Posted Jul 22, 2013 09:33 AM
    Software revison: K.15.09.0012
    ROM version: K.15.28
    My switch rebooted. Event log shows:
    Mgmt module 1 went down. Software exception at block.c:1158 -- in "eRouteCtrl", task ID=0xa9bc400
    This is the first time it happened. Anyway to find out what happened?
  • 2.  RE: 540zl mgmt module crash
    Posted Aug 02, 2013 03:32 PM
    If you check the manuals there are a number of ways to check to see what happened.  Depends on the configuration of your switch and what components you have installed.  The one you want would be the Management and Configuration Guide.  It will tell you how to view the different log files.
