In general these steps should work:
- Create a bridged forwarding mode WLAN.
- Under Network > Configuration > General > Advanced > Miscellaneous make sure "can be used without uplink" is enabled and "disable SSID when" is set to None.
- Create manual device level overrides for static channel assignment/EIRP in Access Points > [AP] > Radio.
- Make sure the configuration syncs to the AP.
I've seen an oddity on 10.7.1.1 where the AP will reboot after 6 minutes on first bring up on a power injector alone and then subsequently will remain up. Try it out and let us know if this works for you.
Original Message:
Sent: Apr 14, 2025 09:53 AM
Subject: 700 series AP survey mode
Is there a way to enable a standalone/survey mode on 700 series APs to allow them to be used for wireless site survey?
