Comware
  • 1.  7503 - 7506 pro advice
    Posted Jun 19, 2015 08:48 PM
    Dear Folks,
    Our hospital purchased HP 7506 (core) 7503 (distribution-JD240B) 5500 (edge-JG240A)
    1- Edges are only 1G uplink ! , what module to install to have 10G uplink ?
    2- distibution has 48 SFP ports & 48 RJ 45 ports, for the edge uplink (10G), I need to (14 ports) with 10G (SFP+) installed in
    Distibution, is that possible ? If Yes, which SFP+ is compatible with 7503 ?
    The manual list the below but I'm not fully understand what does it mean
    2 switch fabric slots
    3 I/O module slots
    Supports a maximum of 28 10GbE ports or 144 autosensing
    10/100/1000 ports or 144 SFP ports or 12 40GbE ports, or a
    combination
    We're having increased numbers of pateints & I'd really appeciate your kind support
  • 2.  RE: 7503 - 7506 pro advice
    Posted Jun 20, 2015 08:29 AM
    For 7500 series switches, I have not seen 10G modules with more than 8 ports.
    HP 7500 8-port 10G SFP+ Module JF290A
    Transceiver choice depends on what kind of fiber infrastructure you have (SM, MM, distances).
    All products numbers can be found here:
    http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=4177519&docId=emr_na-c02948807#N1012D
  • 3.  RE: 7503 - 7506 pro advice
    Posted Jun 20, 2015 04:18 PM
    Thank you TerjeAFK for your intervene , It's the 1st time for me to get introduced to such modules & I searched the site here & checked the compatibilities as well.
    I only need to confirm 2 final things with you .
    Do I need to purchase HP750048p1000BASE-TPoE+SC Module  - JG663A ) ? knowing we've 7506 free 48p POE+
    Do I need to purchase any software managements such as JG747AAE & H7J34A3 SUS (HP IMCStd SW Plat E-LTU) ?
    Thank you very much
  • 4.  RE: 7503 - 7506 pro advice
    Posted Jun 22, 2015 04:17 AM
    To your first question: you only need to buy the JG663A if you need connect a number of PoE+ devices directly to your core or distribution switches. PoE+ devices are typically wireless access points.
    Second question: IMC is nice to have if you have a number of HP switches to manage, but you do not need it for your 7500 switches to work. We have hundreds of HP switches, so we use IMC for monitoring, upgrading and configuring these switches. If you just have a few switches I would use CLI/web to manage them, and maybe look at something like Nagios (freeware) for monitoring.
  • 5.  RE: 7503 - 7506 pro advice
    Posted Jun 22, 2015 11:59 PM
    So what we're having now is 48p module POE+ JD211B
    We will connect our servers to that module, is that okay ?
  • 6.  RE: 7503 - 7506 pro advice
    Posted Jun 23, 2015 01:16 AM
    As long as your servers use 1 Gbit connection that is fine.
