Hi
@ac,
JL075A is 3810M, not 8310 and has very few in common with AOS-CX-based 83xx and 84xx series switches, so I wouldn't compare them.
ECN is not supported on 3810M switches.
Ivan Bondar
Original Message:
Sent: Oct 17, 2022 04:52 PM
Subject: 8310 JL075A ECN
Hey guys,
Does anyone know if the 8310M switch supports ECN (Enhanced Congestion Control) - I know this is part of 8325/8360/8400 on AOS-CX as per the below doc
c21749d8-c06c-403f-8a36-1e0d104ca625_file.pdf (higherlogicdownload.s3-external-1.amazonaws.com)
The 8310 runs AOS however, I looked through the latest release notes, docs etc and can see QoS but not ECN. I'm assuming it's a no, but some input here would be good as the no means a two-site core replacement ;-) so need to be sure.
