Wired Intelligent Edge
  • 1.  8400 Feature Detail
    Posted Sep 06, 2017 09:37 AM
    Hi Guys,
    Im looking for some resource that gives me a a more in depth explanation of some of the features provied by the 8400. More than what is provided by the datasheets. Is there any other guides, maybe a config guide that i can refer too?
    Also, does anyone know if firware updates are fully in service or if there is downtime? I can see that individual modules can be upgraded.
    #8400
  • 2.  RE: 8400 Feature Detail
    Posted Sep 08, 2017 03:41 AM
    Hi, it's probably the best if you contact an Aruba SE in your region. Let me know if you need support with a contact person.
