  • 1.  8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 05, 2020 04:36 PM
    We are running three 7220 controllers in a L2 cluster on 8.5.0.2. I noticed that the client load balancing is all off and almost all clients are on one controller. There are a few hundred clients on the other two controllers, but in general, the majority are on one controller (the cluster leader).
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 20%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 50
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    peer x.x.x.1 128 L2-Connected CONNECTED (Leader, last HBT_RSP 82ms ago, RTD = 0.476 ms)
    self x.x.x.2 128 N/A CONNECTED (Member)
    peer x.x.x.3 128 L2-Connected CONNECTED (Member, last HBT_RSP 77ms ago, RTD = 0.403 ms)
    x.x.x.1:
    ipv4 wireless Users: 7434
    mac auth: 224
    dot1x: 7186
    captiveportal: 12
    other: 12
    x.x.x.2:
    ipv4 wireless Users: 223
    mac auth: 178
    dot1x: 35
    captiveportal: 5
    other: 5
    x.x.x.3:
    ipv4 wireless Users: 196
    mac auth: 139
    dot1x: 41
    captiveportal: 9
    other: 7
    What's going on here? Anyone else having the same issue?
  • 2.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 05, 2020 05:25 PM
    What was the last infrastructure change that you made?
    What is the output of "show lc-cluster load distribution client"?
  • 3.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 08:57 AM
    The last change we made was months ago when we added an additional controller. Early in the morning with not a lot of clients, here is the output:
    peer x.x.x.1 48 1639
    self x.x.x.2 1673 47
    peer x.x.x.3 40 19
  • 4.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 10:46 AM
    peer x.x.x.3 40 19
    The platform limit of a 7220 is 24,576
    For Active user load balancing to happen, two things must be true:
    1. Active Client Rebalance Threshold = 50% - One controller must have 50% of its platform limit or greater
    2.  Unbalance Threshold = 5% - The difference in users between two controllers  the most heavily loaded controller and the least loaded controller must be greater than 5%
    Since your Active Client Rebalance Threshold is not being met, there is no active user load balancing.
  • 5.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 10:52 AM
    So I'm not sure I understand why there is no rebalancing. The difference between two controllers needs to be greater than 5%? One controller has the bulk of the load, why does that not factor in as one of the two controllers?
    I mean right now we have about 5k clients on and the load balance is the same except the cluster leader now has 5k instead of 1k. The difference between .1 and .2 is way more than 5% as is the difference between .2. and .3. Where there isn't a difference more than 5 percent is between .1 and .3.
    So I guess I'm not sure how that unbalance threshold is calculated.
  • 6.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 11:00 AM
  • 7.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 11:02 AM
    Oh okay.
    Do you think it's worthwhile to adjust the load balancing parameters to get a more even client balance? Or can that cause more issues?
  • 8.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 11:12 AM
    You could certainly try that.
  • 9.  RE: 8.5.0.2 L2 cluster client load balancing issue
    Posted Feb 06, 2020 11:13 AM
    Thank you very much for the information and assistance. Appreciated.
