A wireless lan card problem
  • 1.  A wireless lan card problem
    Posted Jan 30, 2005 08:09 PM
    If a wireless lan card supports 802.11b/g, may I know it's max speed?
    Eric FJ
  • 2.  RE: A wireless lan card problem
    Posted Jan 30, 2005 08:53 PM
    Hi
    Max spped will be mentioned on the Lan card document
  • 3.  RE: A wireless lan card problem
    Posted Jan 30, 2005 09:32 PM
    what is your card model number ?
    prduct code ?
    Sunil
  • 4.  RE: A wireless lan card problem
    Posted Feb 16, 2005 06:35 PM
    Theoretical maximum on 802.11b is 11mbit/sec, on 802.11g, it's 54mbit/sec.
    Having said that - you need to be aware that the actual throughput is going to be less, depending on any number of variables - your distance from the access point, any walls, etc. in between your client & the access point, other systems associated with the access point and the type of encryption used - if any.
    Under ideal conditions you can expect 802.11b to deliver approximately 6mbit/sec and 802.11g, 32mbit/sec.
    Please be aware that although 802.11g is backward compatible with 802.11b - a single 802.11b client associated with an 802.11g access point, can cause significant performance degradation for 802.11g clients using the same access point.
