Comware
  • 1.  A5120 Link Aggregation witn NIC
    Posted Aug 31, 2011 04:16 PM
    Is there a way to set up LACP  or static aggregation between A5120 and 4-port GB card?
    Thank you.
  • 2.  RE: A5120 Link Aggregation witn NIC
    Posted Aug 31, 2011 04:59 PM
    Sure. Look at the port link-aggregation command in interface context.
  • 3.  RE: A5120 Link Aggregation witn NIC
    Posted Sep 04, 2011 08:05 AM
    Don't forget that you need to set up 'interface Bridge-Aggregation ...' as well.
  • 4.  RE: A5120 Link Aggregation witn NIC
    Posted Sep 06, 2011 09:23 AM
    Yes, i tried this. Both LACP and Static aggregation.
    But the Intel 4x1Gb with static aggregation set in driver doesn't work.
    Switch tells that  ports are misconfigured.
    I have tried to follow H3C manuals using both telnet commands and web interface. Nothing helped, even software upgrade to 2208.
    Not sure whar the issue is. maybe, reconfiguration from scratch is needed?
  • 5.  RE: A5120 Link Aggregation witn NIC
    Posted Sep 06, 2011 06:27 PM
    Post the relevant portions of your switch config and we may be able to spot any issues.  My guess from what you've said is that the host side is not set up appropriately.  If it's running Linux or VMware, i may be able to help on that side of things as well.
