You need to make sure that the switch could reach the RADIUS server from the specified VLAN. Do you have multiple IP interfaces on the switch? If yes, is routing configured correctly in the network?
Original Message:
Sent: Feb 24, 2023 01:07 AM
Subject: AAA Authen Radius remote management ip source-interface radius vlan 10
HI Aruba WB @Aruba WB
I used:
radius-server host 10.0.0.221 key "key"
radius-server host 10.0.0.221 dyn-authorization
radius-server host 10.0.0.221 time-window 3000
ip source-interface radius vlan 200
aaa authentication num-attempts 2
aaa authentication login privilege-mode
aaa authentication web login peap-mschapv2 local
aaa authentication web enable peap-mschapv2 local
aaa authentication ssh login peap-mschapv2 local
aaa authentication ssh enable peap-mschapv2 local
Vlan 200 Managent vlan switch virtual interface
van 10 server where Radius server is/ Radius server is a different box with DC server.
For some reason, web UI cannot authenticate with Radius server:
I got this error:
W 02/24/23 17:15:44 00419 auth: AM1: Invalid user name/password on WEB-UI
session User 'unknown' is trying to login from dektop
W 02/24/23 17:15:10 00419 auth: AM1: Invalid user name/password on WEB-UI
session User 'unknown' is trying to login from desktop
I 02/24/23 17:15:05 00421 radius: AM1: Can't reach RADIUS server 10.0.0.221
Radius server and lab switch is all working fine but switch and server are within the same vlan.
Any idea why?
ML
Original Message:
Sent: Feb 23, 2023 06:14 AM
The switch will automatically select the IP interface of the outbound interface by default to reach the RADIUS servers. If you need to change this you need to use the ip source command.
Regarding the wrong credentials. Is the RADIUS server sending a deny or is it just dropping the authentication request?
William Bargeman
Systems Engineer Aruba
Original Message:
Sent: Feb 23, 2023 12:02 AM
Dear Friends,
My last question: I used this command
vlan 10
name "management"
untagged 3-10
tagged 13
ip address 192.168.0.254 255.255.255.0
exit
in my Lab so Radius remote management is working with switch management interface 192.168.0.254. Also, Radius server is 192.168.0.55 which is in the same scope VLAN with Switch management interface.
However, if I do not use this command, Radius Management wont be working. So what if the Radius server is in a different scope for exmple, vlan 80. Should I go: ip source-interface radius vlan 80?
Also how can I monitor logs of who logged in the switches? External SNMP server?
ML
