  • 1.  AAA FastConnect problem (802.1x with NPS, termination on the controller)
    Posted Sep 04, 2017 06:23 AM
    I have a configured lab test environment, which contains an Aruba 7x00 Controller, a couple of APs, and a Windows based RADIUS (NPS) server.
    Everything works fine, users can authenticate, till I enabled the termination on the controller. Do I need to install any certificate on it to make it works? (tried install the server cert used for connect on the clients, but got error message: Error Uploading Certificate: Cert missing private key and failed to find a key generated from a CSR request in the system to match it)
    NPS configuration:
    NPS Networks PoliciesNPS Networks PoliciesNPS Connection Request PoliciesNPS Connection Request Policies
    User access before Termination enabled (works):
    Denyed access after Termination enabled:
    As I see users try to connect by EAP-PEAP and MSChapv2, and that was enabled in the network policy, but correct me!
    (Controller configuraton attached.)
    Attachment(s)
    txt
    mb_config.txt   26 KB 1 version
  • 2.  RE: AAA FastConnect problem (802.1x with NPS, termination on the controller)
    Posted Sep 04, 2017 06:29 AM
    Hey, you will need to upload the certificate to the controller. Have you taken a look at the below yet? Do you have a CSR and a certificate generated or a certificate already with the private key combined in it?
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-dot1x-termination-work/ta-p/178566
  • 3.  RE: AAA FastConnect problem (802.1x with NPS, termination on the controller)
    Posted Sep 04, 2017 07:43 AM
    @SkiP wrote:
    NPS configuration:
    If you have authentication working with your radius server, turning on Termination (AAA Fastconnect) does not add anything.  Termination is a workaround for users who cannot get a certificate on their radius server or are forced to authenticate to LDAP.  Authenticating to a radius server with Termination enabled would require you to upload a server certificate to your controller which is more work, for the same authentication you already have working...
