Wired Intelligent Edge
"aaa port-access" commands removal
  • 1.  "aaa port-access" commands removal
    Posted Jun 15, 2023 02:14 AM
    For logging of related connected devices access switch has following "aaa port-access" commands:
    interface <>
       name "Acess Points"
       qos trust dscp
       power-over-ethernet critical
       poe-lldp-detect enabled
       mdix-mode mdix
       untagged vlan 1
       no cdp enable
       no snmp-server enable traps link-change
       aaa port-access authenticator control authorized
       aaa port-access authenticator supplicant-timeout 10
       aaa port-access authenticator max-eap-retries 1
       aaa port-access authenticator logoff-period 600
       aaa port-access mac-based addr-limit 256
       aaa port-access mac-based addr-moves
       aaa port-access mac-based logoff-period 600
       aaa port-access mac-based max-requests 2
       aaa port-access controlled-direction in
       aaa port-access auth-order mac-based authenticator
       aaa port-access auth-priority authenticator mac-based
       spanning-tree admin-edge-port
       spanning-tree bpdu-protection
       loop-protect
       exit
    I have not found a way to remove all "aaa port-access" commands when I need it, is it a bug or a feature ?!
    I've noticed such behaiviour on 2930F-48G-PoE+-4SFP+  and 2530-series switches, most likely other types have the same.
  • 2.  RE: "aaa port-access" commands removal
    Posted Jun 30, 2023 11:04 AM
    You can remove those commands by setting them back to the default value. Check here for more details and an explanation.
