Hi
I upgraded MM to 8.10.0.14, and MC keep 8.10.0.12.
MM show switches, all MC and another MM is shown down.
MM show log
isakmpd[12666]: <103103> <12666> <WARN> |ike| IKE SA Deletion: IKE2_delSa peer:10.10.10.11:500 id:4174321071 errcode:ERR_IKESA_EXPIRED saflags:0x41000005 arflags:0x20
MC show log
Oct 1 17:25:11 2024 cfgm[5398]: <399838> <5398> <WARN> |cfgm| LmsHeartBeatResultAction: State(READY:LAST SNAPSHOT:CFGID-442:PEND-0:INITCFGID:0) FD=27:Cannot heartbeat with the conductor.
Oct 1 17:25:11 2024 cfgm[5398]: <399816> <5398> <ERRS> |cfgm| handle_read: State(READY:LAST SNAPSHOT:CFGID-442:PEND-0:INITCFGID:0) FD=27:Failure receiving heartbeat response header information Result=-1 Err=Connection timed out
Original Message:
Sent: Sep 30, 2024 09:21 AM
Subject: about ArubaOS 8.10.0.14
I have a few customers running stable on it. What version is your MM on? Did you upgrade that first? What does it look like from MM when you issue the "show switches" command?
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Sep 30, 2024 06:38 AM
Hi
Is anyone upgrade to ArubaOS 8.10.0.14?
Is stable?
On myself lab environment, MM、MC upgraded to 8.10.0.14 occur MC lost connect and vrrp show status is down.
Thanks.
