  • 1.  about ArubaOS 8.10.0.14
    Posted Sep 30, 2024 06:38 AM
    Hi
    Is anyone upgrade to ArubaOS 8.10.0.14?
    Is stable?
    On myself lab environment, MM、MC upgraded to 8.10.0.14 occur MC lost connect and vrrp show status is down.
    Thanks.
  • 2.  RE: about ArubaOS 8.10.0.14
    Posted Sep 30, 2024 09:22 AM
    I have a few customers running stable on it. What version is your MM on? Did you upgrade that first? What does it look like from MM when you issue the "show switches" command?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: about ArubaOS 8.10.0.14
    Posted Oct 01, 2024 05:29 AM
    Hi
    I upgraded MM to 8.10.0.14, and MC keep 8.10.0.12.
    MM show switches, all MC and another MM is shown down.
    MM show log
    isakmpd[12666]: <103103> <12666> <WARN> |ike|   IKE SA Deletion: IKE2_delSa peer:10.10.10.11:500 id:4174321071 errcode:ERR_IKESA_EXPIRED saflags:0x41000005 arflags:0x20
    MC show log
    Oct  1 17:25:11 2024  cfgm[5398]: <399838> <5398> <WARN> |cfgm|  LmsHeartBeatResultAction: State(READY:LAST SNAPSHOT:CFGID-442:PEND-0:INITCFGID:0) FD=27:Cannot heartbeat with the conductor.
    Oct  1 17:25:11 2024  cfgm[5398]: <399816> <5398> <ERRS> |cfgm|  handle_read: State(READY:LAST SNAPSHOT:CFGID-442:PEND-0:INITCFGID:0) FD=27:Failure receiving heartbeat response header information Result=-1 Err=Connection timed out
  • 4.  RE: about ArubaOS 8.10.0.14
    Posted Oct 01, 2024 03:10 AM
    I upgraded to 8.10.0.14 about 1 month ago, and it is stable and work fine, till now :)
    ACMP ACSP ACCP ACEP ACDP
