about CVE-2024-3596
  • 1.  about CVE-2024-3596
    Posted Jul 29, 2024 02:41 AM
    Hi All
    ArubaOS 8 solution version estimated release on mid-September.
    I think it's been too long, and the risk level is certical!
    I see that workaround enable radsec, but I don't know this part very well
    have any suggestions on how to handle this.
    Thanks.
  • 2.  RE: about CVE-2024-3596
    Posted Jul 30, 2024 09:06 AM
    From the Aruba bulletin:
    Workaround
    Network Operators who rely on the RADIUS protocol for device and/or
    user authentication should update their software and configuration
    to a secure form of the protocol for both clients and servers.
    Where available, using EAP-TLS (assuming Message-Authenticator is
    properly configured on the RADIUS server) or RadSec will mitigate the
    vulnerability. This work around applies to all products.
    In instances where product upgrades are not available,
    network isolation and secure VPN tunnel communications should
    be enforced for the RADIUS protocol to restrict access to these
    network resources from untrusted sources.
    RADIUS with the fix is still unencrypted and using weak cryptography. It has for years already been a (my) recommendation to run RADIUS only over trusted networks, where an attacker does not have access to. This attack requires a man-in-the-middle, which requires someone to be in the middle of the RADIUS traffic between network device and RADIUS server, which is a situation where I would not like to be in for the previously mentioned reasons.
    I would work with your Aruba partner and/or local Aruba SE to discuss the situation and find the best way forward, where abandoning (cleartext) RADIUS may be one of the scenarios to explore.
