Cloud Managed Networks
  • 1.  About Trunk or Access port for Controller, MM, and AP
    Posted Dec 06, 2022 02:08 PM
    hi all,
    i have tried to find any explanation about when to use trunk or access port on Controller, MM and AP, but until now i got nothing. so if i have 2 controller, 1 MM, and some of AP, and i want to have multiple SSID with different VLAN on each SSID, what is the best setting for the port on all devices, is it trunk or access ?
  • 2.  RE: About Trunk or Access port for Controller, MM, and AP
    Posted Dec 06, 2022 02:18 PM
    Edited by DB86 Dec 06, 2022 02:18 PM
    Mobility Master is usually Access. Its a management platform mostly
    APs only need trunk if you want to drop off client traffic on the AP uplink port. Otherwise, all access ports to allow the AP to tunnel to the controller
    The controller is 100% where you will want to deploy trunks for the connectivity. Spinning up new VLANs/Subnets will require this.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: About Trunk or Access port for Controller, MM, and AP
    Posted Dec 06, 2022 10:15 PM
    if im using access on AP, then all users will be tunnel to controller, is that also mean that the traffic of my user will be out from the controller ? not from the AP where the user connected to ?
  • 4.  RE: About Trunk or Access port for Controller, MM, and AP
    Posted Dec 07, 2022 06:50 AM
    Yes. The user traffic is carried over the tunnel from the AP to controller. You assign a VLAN to the SSID or the User Role and that's the VLAN they exit through the controller on. If you set up the SSID to be in bridge mode, then you need to trunk that SSID/User Role VLAN to the AP.
    Dustin Burns
