Access rule Destination definitions
  • 1.  Access rule Destination definitions
    Posted Jun 12, 2025 06:33 AM
    When creating access rules, I can't find documentation with definitions for options like:
    To AP IP
    To AP IP all
    To AP Network
    To Conductor IP
    I'm creating a guest network, but DHCP is bridged, so I need to allow DHCP to the gateway of the WLAN. There is no Gateway option, and I'm not sure which of those options accomplishes just that. I can't specify the IP as this WLAN config will spread multiple networks.
    I also don't want clients on the network to be able to access each other.
  • 2.  RE: Access rule Destination definitions
    Posted Jun 12, 2025 01:16 PM
    You allow DHCP, not to the AP network but just in general.  You have to allow the broadcast to happen so that either a local DHCP server or  DHCP relay can happen.  What you want to prevent is allowing a client on that wireless network from replying with a DHCP offer.
    Carson Hulcher, ACEX#110
