Access Tracker "REJECT" Reason and visability - Unique Device Count
  • 1.  Access Tracker "REJECT" Reason and visability - Unique Device Count
    Posted Mar 08, 2019 02:41 AM
    Hello.
    As an cppm administrator daily business has to be simplified where ever possible.
    There are many reasons why an user access is rejected. One of them can be "Unique-Device-Count reached".
    If you are working with the "Unique-Device-Count" and the limit is reached, the output in the Access Tracker looks like "Output: Enforcement Profiles: [Deny Access Profile]".
    If you want it more specific the solution can look like this:
    1. Copy the system defined Enforcement Profile "[Deny Access Profile]"
    2. Adjust the name of the profile. For example --Deny Unique Device Count--"
    3. Due to behavior of CPPM choose "Radius:Aruba Aruba-User-Role = deny" as Attribute
    4. Make sure the Action of the new Profile is still "Reject"
    5. Replace the old [Deny Access Profile] with the new one in your Enforcement Policies -> Rules -> Actions
    Your Access Tracker entry for rejected users who reached the device limit should look like this now:
    Summary: Enforcement Profiles: --Deny Unique Device Count--
    If you find this solution useful or want to add something, please let me know.
  • 2.  RE: Access Tracker "REJECT" Reason and visability - Unique Device Count
    Posted Mar 08, 2019 08:05 AM
    You should never put anything in brackets.
    Brackets mean it was an out of box/stock element.
  • 3.  RE: Access Tracker "REJECT" Reason and visability - Unique Device Count
    Posted Mar 11, 2019 05:49 AM
    Hi cappalli!
    Thank you very much for your hint!
    I've edited the post obove for further use.
