  • 1.  Accesspoint SSID Bridged and Tunneled
    Posted Dec 12, 2024 08:31 AM
    Hi All.
    Have a Problem with an Accesspoint, located in a Remote Office. Connected to the Conductor as a CAP.
    i'm running there several SSID
    One of them should be tunneled to the Controller.
    Problem seems to be that one Bridged SSID need the same VLAN ID as the Tunneled SSID.
    At first i tought, no Problem because one is bridged and the other one is tunneled. But it did not work.
    Should i have to pick two diffrent VLAN IDs ?
    Thanks.
    Peter Blumenau
  • 2.  RE: Accesspoint SSID Bridged and Tunneled
    Posted Dec 12, 2024 09:38 AM
    Edited by chulcher Dec 12, 2024 10:01 AM
    AOS 8 doesn't support a mixed mode WLAN, that's a feature of AOS 10.
    Carson Hulcher, ACEX#110
  • 3.  RE: Accesspoint SSID Bridged and Tunneled
    Posted Dec 13, 2024 04:04 AM
    CAP with WLAN Gateways in AOS8 are designed for tunneled mode. Bridge mode is possible when using a different vlan id.
    Only use it in a small environment with max. 16 AP within the same roaming domain, you should avoid bridge-mode in larger designs.
    Please note that captive-portal isn't supported in bridge-mode. More info see the Arubao AOS8 Fundamentals Guide.
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 4.  RE: Accesspoint SSID Bridged and Tunneled
    Posted Dec 13, 2024 10:55 AM
    Bridge mode is limited to 32 APs per L2 broadcast domain and captive portal is supported, although requires specific configuration and using a server initiated workflow.
    Bridge mode, at least when using AOS 8, should also be avoided due to these limitations and challenges.  Instant or AOS 10 would be better options.
    That said, running an AP in a remote office with the controllers located across a WAN link is only supported when running in Remote AP mode which is analogous to a Microbranch AP in AOS 10.
