  • 1.  Activate IP pool
    Posted Aug 08, 2013 12:55 PM
    Hello Experts.
    A quick question: in order to allow our IAP-105 to leverage from the zero-touch configuration feature, we need to allow, from our firewalls, the outgoing connections to activate.arubanetworks.com on port 443.
    Unfortunately our firewalls does not allow rules based on FQDN, so I need to open on IP. Is there a pool or a set of known Aruba Networks IP for this service? For example, if I resolve the name now I get 199.27.105.184, but I guess it can change.
    Thanks a lot!
  • 2.  RE: Activate IP pool
    Posted Aug 08, 2013 07:03 PM
    I am not sure if it will change but the IAPs actually use device.arubanetworks.com.
  • 3.  RE: Activate IP pool
    Posted Aug 13, 2013 09:28 AM
    I just spoke to engineering.  device.arubanetworks.com is currently set to respond to a static IP of 199.27.105.185.  There is no guarantee, however, that this won't change in the future.
  • 4.  RE: Activate IP pool
    Posted Aug 13, 2013 09:46 AM
    Thanks a lot!!
