Using 8.6.0.4, with a 2 node 7240XM cluster, and trying to bring up an AP-303H as a RAP, using Activate for ZTP.
When syncing the activate whitelist to the MM, I get *every* AP from activate in the list, and they all get assigned an inner IP from the cluster rap pool. I'm not comfortable with my campus APs being in my RAP whitelist.
Next I set up external whitelisting in Clearpass, and I only get the devices that are in the specific folder that I'm testing with. But, they don't get an inner IP.
I've seen some 8.0.1 docs that say external whitelisting can't be used for clusters, but a lot of other stuff has changed since then.
I think I'm down to either manual whitelisting on the MM, or assigning the IP in Clearpass.
Anyone see something I missed?
Andrew
