Network Management
Activating Local VLAN in 3810 switch while using 802.1x but if ClearPass inaccessible.
  • 1.  Activating Local VLAN in 3810 switch while using 802.1x but if ClearPass inaccessible.
    Posted Feb 01, 2017 05:43 AM
    Hi Folks,
    I'm using 802.1x with 3810 switch and Clearpass.
    If Clearpass is inaccessible, I am planning Siwtch to assign the user in a static vlan and continue to working locally.
    When Clearpass is inaccessible remains the user in the Conecting state and there is no vlan assignment.
    I made the following settings for this and the debug outputs are below which is just after the Clearpass is inaccessible by the switch.
    Is there a any other way to stabilize this. Thank you.
    radius-server dead-time 3
    aaa authentication port-access eap-radius authorized
    interface 1/1
    broadcast-limit 2
    untagged vlan 1099
    aaa port-access authenticator
    aaa port-access authenticator tx-period 60
    aaa port-access authenticator supplicant-timeout 120
    aaa port-access authenticator max-requests 3
    aaa port-access authenticator reauth-period 10
    aaa port-access authenticator client-limit 1
    aaa port-access mac-based
    exit
    sw-k1-stack# show port-acc auth clie 1/1 det
    Port Access Authenticator Client Status Detailed
    Port-access authenticator activated [No] : Yes
    Allow RADIUS-assigned dynamic (GVRP) VLANs [No] : No
    Use LLDP data to authenticate [No] : No
    Client Base Details :
    Port : 1/1
    Client Status : Connecting Session Time : 0 seconds
    Client name : Session Timeout : 0 seconds
    IP : n/a MAC Address : 001e33-0d5c6e
    Access Policy Details :
    COS Map : Not Defined In Limit Kbps : Not Set
    Untagged VLAN : Not Set Out Limit Kbps : Not Set
    Tagged VLANs : No Tagged VLANs
    Port Mode : 1000FDx
    RADIUS ACL List : No Radius ACL List
    Attachment(s)
    txt
    3810_aaa-radius_debug.txt   16 KB 1 version
