Wired Intelligent Edge
  • 1.  Active-gateway ping or ssh don't work
    Posted May 10, 2021 10:42 AM
    I have a strange behaviour on 8325 vsx as my active-gateway below doesn't respond to ssh/ping:
    interface vlan 34
    vsx-sync active-gateways
    ip address 192.168.34.2/23
    active-gateway ip mac 12:01:00:00:01:00
    active-gateway ip 192.168.34.150
    the configuration is the same on peer
    from a distribution switch ping/ssh is ok to ip address of both peer
    the arp resolution is ok for the ip active-gateway
    no vrf on the network ...
    What could be the problem, I'm loosing my mind .... the active-gatway funcitonnality would be used for routing for others vlan,
    I must to be sure that's all is ok before plan a migration.
    stephane henrot
  • 2.  RE: Active-gateway ping or ssh don't work
    Posted May 10, 2021 01:40 PM
    Does it respond to ping from devices on the same subnet/VLAN?
    Dustin Burns
  • 3.  RE: Active-gateway ping or ssh don't work
    Posted May 12, 2021 03:18 AM
    HI,
    I made en extended ping from a cisco device by specifying the source address in vlan 34 and it doesn't work.
    I created a second active-gteway for another vlan (with same active mac ) and after that both active-gw were reachable ...?!?
    I deleted the new active-gw and the ping to the acti-gw for vlan 34 doesn't work ....
    I don't understand why .... and this behavior for me seem to be like a bug.
    I think i have to open a tac case.
    Brgds
    stephane henrot
  • 4.  RE: Active-gateway ping or ssh don't work
    Posted May 12, 2021 07:25 AM
    I guess the next thing I would check is the L3 path to and from VLAN 34 (routing). I know it doesn't sound like it, but it sounds like something is definitely in play somewhere at L3 or L2 over a trunk. Enabling another L3 interface fixed it, and maybe its reachable through that?
    Dustin Burns
  • 5.  RE: Active-gateway ping or ssh don't work
    Posted May 12, 2021 07:35 AM
    I understand but how to explain that the ip address of the interface vlan reply to ping and not the active-gateway ip.
    the L2 is ok (arp resolution is ok for both address) and i ping "from" the vlan34 on another switch so no routing process involved.
    Let's see what the TAC reply after investigation....
    Brgds.
    stephane henrot
  • 6.  RE: Active-gateway ping or ssh don't work
    Posted May 12, 2021 08:31 AM
    Ahh OK I didn't know you were able to ping the L3 interface. Yea that's strange.
    Dustin Burns
  • 7.  RE: Active-gateway ping or ssh don't work
    Posted May 19, 2021 03:50 AM
    for me, it is "normal" the SSH can't work on Active Gateway... (but ICMP should work)
    ACEP / ACMX #107 / ACDX #1281
