  • 1.  Add snmp on cppm
    Posted Oct 13, 2021 05:58 AM
    Hi. I need to add new snmp entry on cppm. Can i check if there will be any services that need to restart after adding? Will it cause any downtime to the network?
    Grace See
  • 2.  RE: Add snmp on cppm
    Posted Oct 14, 2021 06:12 AM
    As in an SNMP Trap receiver, or as in the SNMP service on the ClearPass server for remote polling of the ClearPass.
    In both cases, I don't think you need to restart anything, and I don't think there is any service outage except possibly for the SNMP service itself (very short), but you change the configuration so it should practically not be an outage.
