  • 1.  add vlan virtual-AP
    Posted Feb 20, 2017 11:26 AM
    Just sprung up a new AP system at my main hospital.
    The Guest /21 subnet has filled up. I was already planning to migrate to VLAN pools but I'll need to do this one in advance.
    From what I read, it looks like changing the vlan assignment on my guest vap will reboot the AP. Can someone confirm?
    If this is the case, is there a graceful way to do this without rebooting the AP? I was thinking I can remove the Guest vap from the group -change it to a pool- and then add it back. Although it would be a pain for 30+ groups.
  • 2.  RE: add vlan virtual-AP
    Posted Feb 20, 2017 11:47 AM
    It will not reboot the AP, but it will kick all the users of that SSID.
  • 3.  RE: add vlan virtual-AP
    Posted Feb 20, 2017 02:02 PM
    thanks Colin, I was able to confirm this through a test AP.
    one more quesiton, When I assign a vlan pool to the vap, the radios disable. I've been looking through the configuration and can't find anything that would cause that...
  • 4.  RE: add vlan virtual-AP
    Posted Feb 20, 2017 02:07 PM
    Nevermind. Found it.
    For others:   VLAN assignments are per controller. Had to add to 2 other local controllers in the VLAN pool.
  • 5.  RE: add vlan virtual-AP
    Posted Feb 21, 2017 03:37 AM
    Hey, don't forget you can also check the config for errors using the below command
    #show profile-errors
    It would tell you if there is a VLAN missing and so on:
    wlan virtual-ap "Corp-SSID"   VLAN 167 does not exist
