I take it you are currently running the 16.02 firmware. Can you please upgrade your switch firmware to 16.03.0003 and re-run your test? It is possible that the error you see was a switch firmware bug that was fixed in 16.03.
Thanks again Abhay for your reply. You are right when I upgraded to 16.03 the error disappeared, and the match fields were added.
The OXM field is the upper 7 bits of the byte and the lower bit is used to determine if the field is maskable. Hence when the field is 5 with no masking capability, it translates to a value of 0xa for the byte and 0xc for field 6.
Aha I see, I hope the guide gets updated to include this in defining a custom field instead of using 0x05 and 0x6 (I believe with masking capability it would be 0xb and 0xd).
Ok, now I am trying to understand the format of the flow mod message. Let's take the TCP_ACK_NUM(Field=6)=0x98765432 match example. According to the flow-mod example you sent the match for the TCP_ACK_NUM should be :
ffff 0c 18 00002481 00000004 98765432
I am a bit confused about the 0x18. which in the guide explained as the OXM_LEN: The length of the experimenter header excluding the OXM header. So why is it 0x18 since we set the oxm_len to 0x0a in the table features?
I am trying to define a custom field of 128bits (16 bytes) that is parsed after the UDP header (8 bytes). I defined the field as the following in the table feature:
ffff 0a 0a 00002481 0003 0008 0010
The field is created successfully on the switch.
However, when I create a flow-mod to match against this field I get an error of OFBadMatchErrorMsgVer13(xid=46, code=BAD_FIELD, and sometimes the switch suddenly reboots!
Is this how the match of my field in the flow-mod should look like ??
ffff 0a 14 00002481 00000010 3133 5444 4538 3930 3631 3433 3638 3730
where 0x31335444453839303631343336383730 is my match data.
