Yes, that could definitely be the case. To fully delete devices, you would need to contact Aruba support.
Also, for the devices that are now blocked (and you don't know where), it's probably easiest to open a support ticket and let TAC find out where those devices are registered now and if possible 'release' them.
Original Message:
Sent: Aug 31, 2022 05:44 AM
Subject: Adding devices to HPE Greenlake
Thanks for the clarification.
We did recently trial Central On Prem - I'm wondering if adding devices there is what is blocking us adding them to the test GreenLake account. Could that be the case?
Original Message:
Sent: Aug 31, 2022 04:38 AM
To be a bit more precise: Devices can be moved to another account if they are both:
- Not archived
- Not have an active subscription
So un-archive the device and make sure it has no active subscription; then you can move it to another account.
Original Message:
Sent: Aug 30, 2022 12:43 PM
Not to my knowledge. Some of them are in ASP, we're going to try removing them from there.
Just as an aside - we added one of our live controllers as a gateway in our test instance of GreenLake (just to prove to ourselves that we could add a device), that is archived now but will that mean that when we come to use that device as a gateway in future (when we complete the move to AOS10 sometime in the distant future!) is that going to cause problems adding it to our non-test GreenLake tenancy? If so is there anything we can do to fix this now?
Original Message:
Sent: Aug 30, 2022 07:33 AM
were those 7220 gateways had been added to another GLCP tenant already and then archived?
Original Message:
Sent: Aug 30, 2022 05:33 AM
We are trialing a test instance of Central (cloud), we want to add some of our old controllers (all now out of support) to Greenlake so we can try them out as gateways. But when we try to add them we get an error:
We get this error with all but one of the 7220s (that is also out of support) that we tried adding. As a test we added one of our live controllers (7240XM) and that worked fine.
This is an example of the error we get when trying to add them
