Wired Intelligent Edge
Adding members to a VSF in a ring topology
  • 1.  Adding members to a VSF in a ring topology
    Posted Aug 24, 2020 03:04 PM
    Hi to all!
    I would like you to please recommend what is the best strategy to add members to a VSF in a ring topology of 4 Aruba 2930F switches without MAD. The idea is to minimize the disruption of services as much as possible.
    Thank you very much.
    Best regards
    Gabriel
  • 2.  RE: Adding members to a VSF in a ring topology
    Posted Aug 24, 2020 07:39 PM
    Hi Gabriel, technically speaking an Aruba 2930F VSF deployed using a Ring Topology (thus where last VSF Member is connected back to first VSF Member) is not going to suffer of a VSF Split scenario in case the VSF Ring is necessarily broken to add an additional VSF Member...that's because - with the ring opened - any VSF Member is still connected to any other VSF Member through the resulting chain (that's the contrary of what is going to happen having a VSF deployed using a Chain Topology and you break the chain of VSF links for the very same purpose).
    Have a look here for Best Pratices about new VSF Member provisioning.
