Hello!
We have several Aruba AP-505 in one site.
The all are added to one AP-Group.
Thats good and everything works.
I wanted to add another AP-505 which is in another subnet. I learned that I have to tell that AP the IP of the conductor. That works by DNS "aruba-master" or DHCP with option 43.
But the remote AP is not added to the others.
I switched on logging and there I found an error:
error: avoid installing virtual controller ip 192.168.1.1 on mgmt vlan as it does not match with ap-ip subnet 10.0.0.0/24
Does anyone know how to fix this?
Thank you!
Alex.
