  • 1.  adjust MTU between local WLC and mobility master (MM)
    Posted Aug 23, 2021 10:56 PM
    For communication between local WLC and mobility master (MM) they build a tunnel between each other, which ads additional headers to packets.
    Should MTU be adjusted to make stable communication between them ?!
    I haven't found on MM the way to set MTU size, does such possibility exists ?!
    AY
  • 2.  RE: adjust MTU between local WLC and mobility master (MM)
    Posted Aug 24, 2021 02:38 AM
    You can adjust to be 9126 bytes as maximum on the head-end.
    Ratchapas Shatsa-Nga
  • 3.  RE: adjust MTU between local WLC and mobility master (MM)
    Posted Aug 24, 2021 03:09 AM
    ok,
    would be good to see command lines how to adjust MTU (I havent found neither on Web-form nor in command line)
    Andrii Yefremov
  • 4.  RE: adjust MTU between local WLC and mobility master (MM)
    Posted Aug 24, 2021 03:24 AM
    I can't remember where to configure, try in Interface or Firewall.
