  • 1.  adopting APIN0515 to 7024 Controller
    Posted Dec 13, 2021 10:06 AM
    I have been trying to adopt my APIN0515 to 7024 controller without success.
    The controller is not even able to see my APs even when directly connected to it.
    Any help would be appreciated.
    Thanks in advance.
    Otutey Agorhom
  • 2.  RE: adopting APIN0515 to 7024 Controller
    Posted Dec 13, 2021 01:05 PM
    What version are you running on the 7024?
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: adopting APIN0515 to 7024 Controller
    Posted Dec 14, 2021 07:50 AM
    Edited by ulises.cazares Dec 15, 2021 09:19 AM
    Hi, the minimum version of software the AP will need installed in the controller is 8.4.0.0. If your controller is in a version less than that, the AP won't be able to join.
    Another thing that you'll need to check is if CPSEC is on, and if it is, allow the new AP mac address in the whitelist
    Hope this helps
    Ulises Cazares
