Some devices (in the past) have shown incompatibility with some of the 802.11 substandards like 11d and 11k. Probably for that reason it's disabled by default.
You can use Aruba Utilities (Android) to display beacon information in a nice way.
In Aruba Central, enabling 11d and 11h is the same option, so they seem to go together. In general, the defaults in Aruba are a safe choice and balanced for device performance and compatibility.
Original Message:
Sent: Jan 28, 2024 05:55 PM
Subject: Advertise 802.11d (country) and 802.11h (DFS/TPC) capabilities. Best Practice?
Hello everyone,
is there a current "best practice" regarding the broadcast of 802.11d (country info (channels, power)) and 802.11h (DFS/TPC)?
In particular, I'm concerned with networks here in Europe/Germany, with predominantly only national devices.
Some manufacturers (such as Aruba) have 802.11d disabled by default, is this due to possible compatibility issues or is its use simply outdated?
Does the use of 802.11h always also include 802.11d?
Is this usually activated automatically as soon as channels that require DFS/TPC are used?
Is there a scanner/analyzer app that can evaluate the 802.11d/h information?
Thank you very much for any help!
Greetings, Martin
