Wired Intelligent Edge
  • 1.  Advice on adding switches to a MAS stack
    Posted Apr 29, 2020 07:55 AM
    I've added switches to an existing stack of S2500s and had both good and very bad experiences with it. I wonder if anyone would share what's considered best practices for doing this.
    The issue is that we're taking switches that previously were used in a different switch stack and may have been the primary switch in that stack and wanting that switch to be line card in its new stack. I don't want it to join the stack and try to take over as primary because it's been factory defaulted and has no configuration. I've had the experience of a switch doing just that in a live production environment - it wasn't fun.....
    What I've done to prevent the bad experiences I've had in the past is to:
     - upgrade the firmware on the switch to the same version as the switches in the stack it will be going to;
     - run the 'restore factory-default stacking' command on the switch to try to remove the stacking database that it had;
     - set the election priority on the switch to a number below the default (I arbitrarily chose 50).
    My concern is that, despite doing these steps, the switch still shows its role as primary - probably because it's a standalone at this point - but it also doesn't allow me to set it to a different role, probably for the same reason.
    Is there a sure way of doing this that will result in the desired outcome? I have read the documentation, but it doesn't seem to address this directly.
  • 2.  RE: Advice on adding switches to a MAS stack
    Posted Apr 30, 2020 04:00 AM
    With MAS being end-of-sale for some time, I'm not sure how many people are extending stacks.
    Please check the documentation on ArubaStack, especially the part on ArubaStack pre-provisioning which allows you to prepare the stack and make sure the newly added node will become a line-card.
    Then also check this post, which seems to mention exactly what you experience.
    Also, you may check with Aruba Support if these switches are still covered under active support.
  • 3.  RE: Advice on adding switches to a MAS stack
    Posted May 04, 2020 07:02 AM
    This is the procedure I have used in the past:
    * remove the switch from the previous stack
    * factory reset it and upgrade it to the software running in the new stack
    * change the stack-profile in the new stack and enter the serial number and role of the new switch
    * connect the switch to the new stack
