AOS 8.7.1.5
10x MD active cluster
7x MD backup cluster
One of our customers (a department in the University) has a bridged dot1x SSID on our APs (we have to provide bridged SSIDs to quite a few of the departments and colleges because of the federated nature of the university, and because we don't have a better solution in place yet, believe me we would love to get rid of them if we could!). They have reported that on occasions over the past couple of years the performance on that SSID is very poor (there have been times where they have reported it, then we have performed an unrelated upgrade and the problem seems to be 'solved', only for it to return some months later). I have previously been to the location and confirmed that speeds on that SSID are very poor (though as I say, this is not alway true).
Our view on this is that we have lots of bridged SSIDs and we only get reports of issues from this particular customer, so the feeling is that it could be LAN related (the customer runs the LAN, we just bridge onto it) - however the customer says they are confident the LAN is not at fault. Are there some commands I can run when I have a client connected to that SSID that will tell me if the AP is doing anything funky like throttling traffic? We just want to be able to say that as far as we can tell our system is not at fault here (or give us something to work with if the APs _are_ doing something odd).
Any advice much appreciated.
Thank you,
Guy
Guy Goodrick
