last person joined: 8 hours ago
After typing in Guest Account and Password Unable to Click Accept
This thread has been viewed 22 times
  • 1.  After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 12, 2024 12:07 PM
    Howdy folks, this is an intermittent issue where we've created multiple guest accounts and sometimes when a user logs in with the guest username and password - the user is is unable to click the accept button. Thoughts on why?
  • 2.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 12, 2024 12:42 PM
    Hi
    From the screenshot it looks like a mobile device, does the error occur only on mobile devices or is it random on any device?
    In the text you have a reference to accept the terms and conditions, but I can't see the checkbox to accept. Or have you removed the checkbox and take the click on the button as accept?
    In that case, how did you remove the checkbox. Set it to hidden and always set to True?
    Some additional questions:
    • Do you have more than one accept form or just one?
    • Do you have a custom skin installed
    • What is the frequency of the issue?
    • Do you have several ClearPass servers and the issue only appear on one server?
    • Can you try to create a new form and see if the same issue occur with the new form?
    • What version of ClearPass do you have?
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 16, 2024 09:24 AM
    Hi Jonas, thanks for the reply. It's an intermittent issue with mobile or laptop - the interesting thing is the Terms box is unchecked and we don't have any terms to accept.
    Clearpass 6.11.3.253363
    Brian Mitchell (he/him) | Director Of IT
    Dwight School New York
    18 West 89th Street, New York, NY 10024
    212-724-6360 x456 | dwight.edu
  • 4.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 16, 2024 09:55 AM
    Hi Brian
    Ok, that's strange. I see that you are running 6.11.3 and 6.11.8 is the latest relesed version and .9 is expected in a few weeks.
    I can't find any resolved bug's in the release notes related to your issue, but maybe an update could be worth a try. Also consider some security updates included in the latest versions.
    Have you tried to create a new captive portal page and see if you get the same behavior?
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 5.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 17, 2024 04:44 AM
    Hi Jonas, I have not but will give all those options a try. Thanks again for the help.
  • 6.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 17, 2024 06:02 AM
    Are you sure that this portal page comes from the ClearPass server? It doesn't look familiar to me, and doesn't look like a standard portal page from ClearPass Guest.
    What WLAN (or wired) network do you use? Could it be that the network is handling the captive portal, instead of ClearPass?
  • 7.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 17, 2024 06:19 AM
    That could be totally it. Is my tips role wrong if I create guest passes? Its just strange that it doesn't happen to everyone.
  • 8.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 18, 2024 04:05 AM
    I would have a look at your WLAN/network equipment to see what role/policy is applied. What type of WLAN (model/version) do you have?
  • 9.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 18, 2024 10:17 AM
    Were running Aruba 635's
  • 10.  RE: After typing in Guest Account and Password Unable to Click Accept
    Posted Jul 22, 2024 03:48 AM
    What you share is all ClearPass, I think the solution to your problem is in the AP/controllers.
    I'd recommend that you work with your Aruba Partner or Aruba support. They can check the role of the user when it's receiving the correct captive portal and when it's receiving the wrong portal, as well have a look at your full configuration and fix/optimize where needed.
