Hi parnassus,
Tanks for replay, I think you are right, I didn't know the "Smart Link" feature of HP switches yet, I think that "Smart Link" could be a good solution, but my scenario is a bit different.
I have a point to point radio link that connects Site A to Site B, the radio link has 2 trasmitters (Master and Slave) connected to one antenna by a coaxial switch and two receivers with two different antennas this for Site A and Site B.
In this scenario only one trasmitter is put on air at both Sites, while the receivers are going to receive the same signal at both Sites.
As the result I have two ethernet port that are going to receive the same packets but only the port of on air transmitter is able to trasmit the packets back to the other Site , in other words I always have one port down in one direction.
I need a switch with two ports (Master and Slave) to connecto to the radio link, the switch must be able to select the port that is up at the moment and discarge the packets received from the other one.
Do you think that "Smart Link" feature is an avaiable solution?
Can you tell me about the HP switch models with this feature?
Tanks
