Network Management
  • 1.  Airwave 7.7.12 and RHEL 6.5
    Posted Oct 03, 2014 09:44 AM
    There is a RHEL 6.5 server and we are trying to install the Airwave OS, but getting an error
    WARNING: enabling "trust" authentication for local connections You can change this by editing pg_hba.conf or using the option -A, or --auth-local and --auth-host, the next time you run initdb.
    Success. You can now start the database server using:
    /opt/airwave/pgsql-9.2/bin/postgres -D /var/lib/pgsql/9.2/data or
    /opt/airwave/pgsql-9.2/bin/pg_ctl -D /var/lib/pgsql/9.2/data -l logfile start
    Starting postgresql service: [ OK ]
    Stopping postgresql service: [ OK ]
    Postgres didn't seem to start up. at ./upgrade_postgres_92 line 71.
    make[2]: *** [postgresql] Error 3
    make[2]: Leaving directory `/root/svn/mercury/src'
    make[1]: *** [src_install] Error 2
    make[1]: Leaving directory `/root/svn/mercury'
    make: *** [install] Error 2
    Tried manually restarting postgresql and it did not help.
    Tried running the below command and it did not work.
    [root@airwave ~]# /opt/airwave/pgsql-9.2/bin/pg_ctl -D /var/lib/pgsql/9.2/data -l logfile start
    pg_ctl: cannot be run as root
    Please log in (using, e.g., "su") as the (unprivileged) user that will own the server process.
    [root@airwave ~]#
    Also, tried logging in as “su postgres” and ran the below command and it did not work.
    # /opt/airwave/pgsql-9.2/bin/postgres -D /var/lib/pgsql/9.2/data
    Currently we are reinstalling the RHEL server, but would like to know if there is any fix if we run into trouble again
  • 2.  RE: Airwave 7.7.12 and RHEL 6.5
    Posted Oct 03, 2014 10:04 AM
    If you must install Airwave separately on RedHat instead of using the combined installer, please work with TAC to determine your specific issue.
  • 3.  RE: Airwave 7.7.12 and RHEL 6.5
    Posted Oct 07, 2014 04:21 PM
    Yes we did call Aruba TAC
    And their escalation team installed couple of security updates to install the Airwave 7.7.12 on RHEL6.5
