I know this is an old thread, but I'm putting this here because it was my first search result on Google for "Airwave install hangs usb flash".
If your airwave installation is just hanging there as in the screenshot, you need to edit the boot parameters.
When the first menu screen appears with the "Install AirWave" option, or whatever it is called, press 'e' to edit the parameters.
Change the part that says "
ks=cdrom:/ks.cfg" to be "
ks=hd:LABEL=AIRWAVE:/ks.cfg"
Press Ctrl-X to continue boot. Should work. This assumes that the flash drive is actually named "AIRWAVE". If it isn't adjust that LABEL= section. (Avoid spaces and such in the name unless you want to look up the escape/control codes.)
(Tested on fresh install of 8.2.13)
Dan Scherck
Original Message:
Sent: Oct 22, 2019 11:02 AM
Subject: AirWave 8.2.10.0 Stuck
I'm performing a fresh install of AirWave 8.2.10.0 from 8.2.9. I went through the upgrade process of going to 8.2.10.0, making a backup and then exporting it and now I'm stuck on the fresh install part.
I've tried redownloading the AirWave iso multiple times, recreating a bootable usb drive using 2 different usb drives and 2 different programs to create them and I've tried changing my server from BIOS to UEFI and vise versa. It keeps getting stuck at the same part during boot for several hours each time and does nothing. The screen says some output and the last line is Starting dracut initqueue hook...
I've attached a picture of the screen I'm stuck at each time. Has anyone else ran into this issue? I'm not sure what to do at this point and our 8.2.9 server has been blown away already..
