@Gowri Amujuri wrote:
One thing to try - Remove the LDAP settings in AMP and Readd the details to see if LDAP auth works.
No. Still doesn't work.
Is there a log-file, where i can see ldap-authentication-attempts?
I created a diagnostic-file und looked (grep) thru all the logfiles, but the only thing i could find (in /var/log/amp_events) was ""Failed login attempt".
Or is there anywhere a setting, where i can increase the loglevel for ldap logs?
P.S.
I've manually tested it (ldapsearch on my pc) with the same settings and it worked. So the LDAP-Service /-Server works fine.
