Network Management
  • 1.  Airwave 8.2.12.1/AOS8.7.1.2/RAP 505H
    Posted Jun 03, 2021 12:43 PM
    In my environment, running 8.7.1.2.  I can see the RAP 505h being listed as a device, however I am unable to see any client information on them directly.  I can see clients; I can see under the clients they tell me what RAP they are associated with, however if I go directly to RAP and check out the clients, I get zero (0) information.
    Is this something that will be fixed in the next release of Airwave?  If so, any idea when we expect the release?
    Neal Tarbox
  • 2.  RE: Airwave 8.2.12.1/AOS8.7.1.2/RAP 505H
    Posted Jun 04, 2021 05:49 AM
    If this is not mentioned in the 'known issues' part of the release notes of Airwave or Instant/AOS 8.7.1.2, please open a TAC case for this, either through your partner or direct if you have direct access. Probably a known or unknown bug/limitation.
  • 3.  RE: Airwave 8.2.12.1/AOS8.7.1.2/RAP 505H
    Posted Jun 04, 2021 11:29 AM
    Looks like a bug...  The only thing I could find that comes close, pertains to a Cisco device.
