Network Management
  • 1.  Airwave 8.2.15.1 > 8.3
    Posted Dec 11, 2023 10:21 AM
    Edited by vvajpeyi Dec 11, 2023 10:23 AM
    Hello, I've read the 8.3 release notes and the instructions to upgrade from 8.2.15.1. I wasn't sure if there is  another 8.2.15.X I need to upgrade to before I move on to 8.3.
    Thank you.
  • 2.  RE: Airwave 8.2.15.1 > 8.3
    Posted Dec 11, 2023 12:21 PM
    Edited by vvajpeyi Dec 11, 2023 04:53 PM
    Please note CentOS7 to RHEL8 migration is on specific versions. The reason being having the code base for backup restore to work between different OS platforms.
    RHEL migration path supported are only from 8.2.15.1 -> 8.3.0 and 8.2.15.2 -> 8.3.0.1. Other combinations doesn't work.
     It is mandatory to upgrade to 8.2.15.2 before migrating to Airwave 8.3.0.1".
     "From Airwave 8.3.0/8.3.0.1 you can upgrade to Airwave 8.3.0.2".
    Regards
    Gowri Amujuri
