Cloud Managed Networks
Airwave 8.2.15.2 to 8.3.0.1 upgrade (vm)
This thread has been viewed 36 times
  • 1.  Airwave 8.2.15.2 to 8.3.0.1 upgrade (vm)
    Posted Sep 26, 2023 03:23 PM
    Quick question here...
    Need to upgrade airwave 8.2.15.2 to 8.3.0.1. I understand that due to the move to RHEL8, basically we need to do a fresh install and restore from backup.
    My question is, does the restore from backup bring back network details? That is, when I set up a new VM, I give it a temporary IP address to minimize outage. I would then proceed to restore from backup. Would this also restore the original network information or would I have to change this after restoring (and of course disabling the current VM).
    TIA.
  • 2.  RE: Airwave 8.2.15.2 to 8.3.0.1 upgrade (vm)
    Posted Dec 06, 2023 03:05 PM
    I just did this November 2023. For me it did not bring the IP from the backup over. Installing the fresh gives you 90 day temp license. I had to do a backup, install the fresh VM, import the backup via Putty, and change the IP to the one it was supposed to be.
