Network Management
  • 1.  AirWave 8.2.3 System Requirements
    Posted May 02, 2017 04:24 AM
    can someone point me in the right direction.
    I need official document about system requirements for AirWave on Hyper-V enviroment. In the AirWave 8.2 Installation Guide Aruba has tested Hyper-V on Wind. Server 2000 R2.? I think that this is type failure but i need official document that i can show to my customer.
    Also it would be good to have official document for system requirements (hdd, CPU, RAM) when you are doing installation on virtual enviroment and not something like: "Aruba recommends a 20% increase buffer for virtual environments."
    Thanks.
  • 2.  RE: AirWave 8.2.3 System Requirements
    Posted May 02, 2017 04:36 AM
    Hi Tom,
    Please check Airwave server sizing guide
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/23720/Default.aspx
    Airwave resources allocation varies based on number of factores, please check sizing guide for detail informaiton.
    Pavan
  • 3.  RE: AirWave 8.2.3 System Requirements
    Posted May 02, 2017 04:55 AM
    Hi Pavan,
    that was quick. I did check all these documents that is why i am posting here. :)
  • 4.  RE: AirWave 8.2.3 System Requirements
    Posted May 02, 2017 06:05 AM
    Hi Tim,
    We need to add extra 20% more resources in VM envorinement. If you are planning to monitor around 1500 deivces allocate below recommanded  resourecs with 20% more.
    In VM, allocate
    8 CPU cores
    55GB RAM
    Storege capacity varies depend on historical retention settings,if you have high value allocate recommended disk space.
    Currently we do not have sperate document related to sizing guide for virutal envoirment.
    Pavan
  • 5.  RE: AirWave 8.2.3 System Requirements
    Posted May 02, 2017 07:49 AM
    Hi Pavan,
    i have already gone trough that document. I have found this calculator, that is much better then that document: https://ase.arubanetworks.com/solutions/id/77
    Ok now at least i have that coverd. Can you help me with Wind. Server. In the install document it there is Windows Server 2000 R2!? Should this be 2008 or 2012 ?
  • 6.  RE: AirWave 8.2.3 System Requirements
    Posted May 03, 2017 05:26 AM
    I believe it is tested on 2008R2 but I am not sure exactly, will check and get back to you on this.
    Pavan
  • 7.  RE: AirWave 8.2.3 System Requirements
    Posted May 03, 2017 10:35 AM
    Hi Tom,
    It is tested on 2012.
    Pavan
  • 8.  RE: AirWave 8.2.3 System Requirements
    Posted May 03, 2017 03:56 PM
    Thanks Pavan.
    It would be good if you can push this to be corrected in the official document.
  • 9.  RE: AirWave 8.2.3 System Requirements
    Posted May 04, 2017 05:03 AM
    Sure, will report to the concern team.
    Pavan
  • 10.  RE: AirWave 8.2.3 System Requirements
    Posted Sep 17, 2018 11:19 AM
    Hi guys,
    That calculator is no longer available.
    In my case, the number of devices differs a lot from that of the document. I have around 300 devices, but the minimum hardware tested is for 1500 devices. Should still I considere that platform or reduce the resources proportionally?
    Julián
