Network Management
  • 1.  AirWave 8.2.5 installation broken eth0: error Device not found
    Posted Oct 13, 2017 05:24 AM
    I'm trying to deploy new AirWave 8.2.5 from ova image. But configuration wizard complains:
    eth0: error fetching interface information: Device not found
    My VMs NIC is configured to the generic e1000 type, so there shouldn't be any problem with NIC detection. Furthermore, there is no Linux CLI in AirWave 8.2.5. Thus I'm not able to fix this from the shell.
    Any idea what is going wrong and how to fix this or get access to the CLI at least?
  • 2.  RE: AirWave 8.2.5 installation broken eth0: error Device not found
    Posted Oct 20, 2017 10:31 AM
    Do you get the same result when you try the install off of the ISO?
  • 3.  RE: AirWave 8.2.5 installation broken eth0: error Device not found
    Posted Dec 07, 2017 03:13 AM
    I am facing this issue too with 8.2.5.1. I had uses portable DVD Drive and stuck on line 8 kickstart. The server is HP Proliant DL180 Gen10 with 2x 600GB SAS Intel Xeon Platinum. Any solution for this?Line 8 Error Message.jpgNIC Interface.jpeg
  • 4.  RE: AirWave 8.2.5 installation broken eth0: error Device not found
    Posted Dec 13, 2017 06:37 PM
    Installed the ISO in the lab on a DL360 and it worked.  I've also loaded the OVA on a few different setups.  Can you verify the md5sum for the ISO/OVA image used?
    8.2.5.1]# md5sum AMP*
    3fe53515f20e63ce5a7d6450d379b655  AMP-8.2.5.1-x86_64.iso 2283831296 2.2G
    9b4008f99e8f8a16b1f8e3594843dbd2 AMP-8.2.5.1-x86_64.ova 4042763776 3.8G
