Yes, that is correct. After the ISO setup you log in with root and admin. Then an initial setup script is started, which configures the remaining system settings. As described in the guide sent by @Carson.
Waldemar
ACCX # 1377, ACEP, ACX - Network Security
Original Message:
Sent: Mar 13, 2025 10:51 AM
Subject: AirWave 8.3.0.2 install iso login credentials
This is very strange, i have tried all the combinations but now root - admin is the correct one.
Original Message:
Sent: Mar 13, 2025 10:20 AM
You should be setting the ampadmin password during the initial setup.
Step 5: https://arubanetworking.hpe.com/techdocs/AirWave/830/webhelp/Content/Installation/Installing_Softwa.htm
Carson Hulcher, ACEX#110
Original Message:
Sent: Mar 13, 2025 09:49 AM
Hopefully you can help me with the following, I have installed the AirWave 8.3. 0. 2 install iso on a Hypver-V, but at the moment when it asks for the localhost login, I get a bit stuck.
I have tried the following combinations for username and password, but all combinations do not work.
admin - admin
admin - root
root - root
root - admin
testing - admin
admin - testing
ampadmin - ampadmin
ampadmin - admin
admin - ampadmin
Do you have any other suggestions?
