Network Management
AirWave / AMP 8.2.0 VisualRF is missing clients
  • 1.  AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 01, 2016 05:45 PM
    Hi All,
    I just upgraded to AirWave 8.2. Its sweet!
    One issue that I've noticed so far. All of my clients that I used to see on VisualRF do no appear. Under properties of the floor it shows "Clients: 0" but I have over 50 clients. AirWave sees the clients if I go to Clients tab but just doesnt place them on VRF. APs on VRF are showing green and show other data like channel utilization, rx/tx, access, power, etc.
    I've tried different browsers/workstations to elimate that as an issue. Any ideas?
    N
  • 2.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 05, 2016 05:20 PM
    How much time did you give Airwave after the upgrade? VisualRF can take some time to rebuild the location database for the clients.
  • 3.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 05, 2016 05:35 PM
    I just logged in again for the first time since Friday. Still no data and clients show 0 on properties tab of the floor that I am looking at.
  • 4.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 05, 2016 05:50 PM
    You can try this URL:
    https://[your airwave IP or fqdn]/visualrf/poll_aps_now.xml
    It forces a re-poll of all APs for everything, and usually fixes any missing clients/heatmap events in my installation. If that doesn't help, I'd get a case open with TAC.
  • 5.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 07, 2016 01:17 PM
    That didn't work.
    I opened up a TAC case. Apparently they are seeing this in a few places. May be a possible bug. They took some data/logs and are reviewing. Will update as I know more.
    N
  • 6.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 15, 2016 04:40 AM
    Hi! I also have this issue. Any news from your support ticket?
    thanks!
    /Mikael
  • 7.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 15, 2016 09:02 AM
    Same Issue here!
    With Version 8.2.0.1
  • 8.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 15, 2016 09:04 AM
    Everyone who is replying, please open a TAC case, so that your problem can be looked at and addressed.  It is possible all the issues are different, so if you rely on others to report problems that seem like yours, your issue might not be fixed.
  • 9.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 15, 2016 09:03 AM
    They pulled backups and are rebuilding in lab environment. They have seen this multiple places. Open a ticket so they can validate it is the same problem.
    N
    Sent from Outlook Mobile
  • 10.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Apr 22, 2016 01:35 PM
    TAC has filed a defect for my issue.
  • 11.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted May 12, 2016 04:40 PM
    after 8.2 upgrade, re-check the airwave time zone. If you restore correctly, you will see your clients in VisualRF.
    You could set up in cli with time-setup command.
    Best regards,
    Lax
  • 12.  RE: AirWave / AMP 8.2.0 VisualRF is missing clients
    Posted Jun 15, 2016 10:43 AM
    Defect was patched. After installing the latest version my issue is resolved.
    N
