Network Management
  • 1.  AirWave and PBR (Policy Based Routing)
    Posted Feb 10, 2020 10:09 AM
    Is there any way to configure PBR (Policy Based Routing) for one or a group of switches switches?
  • 2.  RE: AirWave and PBR (Policy Based Routing)
    Posted Feb 10, 2020 04:27 PM
    Hi Lucas,
    Are you trying to configure switches for PBR from Airwave?
    or are looking for configuration steps for PBR on switches?
  • 3.  RE: AirWave and PBR (Policy Based Routing)
    Posted Feb 12, 2020 11:31 AM
    Hi Gowri,
    The first question, I am trying to configure PBR from AirWave.
    Alternatively, can I access the switch Telnet/SSH via AirWave?
  • 4.  RE: AirWave and PBR (Policy Based Routing)
    Posted Feb 12, 2020 11:45 AM
    Hi Lucas,
    I am not exactly sure on the commands that is needed to enable PBR on switches. However, the commands can be used in AirWave in Config snippet(s) to be pushed to a switch or group of switches. Please make sure prior managing or pushing new config to switch from AirWave, the switches are already with 'Good' config status with Template and (optional depending on config) config snippet option.
    There is no option to Telnet/SSH to switches from GUI or CLI menu in AirWave.
