Airwave is an appliance solution, not a general purpose operating system. The information that you request is not publicly available, and even if you had the information you can't do anything with it as the Airwave appliance is locked down, hardened and does not even provide access to the OS. Also, when you upgrade Airwave, many other components are updated, sometimes security fixed within the same version, so it does not help the security process in any way.
Further, I'd recommend to segment/isolate any management systems and traffic to avoid external access.
Please work with your local Aruba SE, through your partner if you don't have direct contact, in case you need to discuss this further or need some written, legal binding confirmation.
Original Message:
Sent: Aug 01, 2024 03:34 AM
Subject: Airwave Architecture Design Diagram
Hi Gowri Amujuri
Thanks for clarifying. Can you please share stable release on Airwave.
Customer need to know RHEL OS version, Postgres DB version, PHP version, Apache version.
Appreciate if anyone can validate below Three tire architecture diagram.
Original Message:
Sent: Jul 11, 2024 10:16 AM
This is something internal to Aruba. We may not be able to share the architecture of the code. I suggest working with your Accounts team for the details.
AirWave is built with RHEL as OS, Postgres for DB, PHP for scripting and Apache for Application layer.
Regards
Gowri Amujuri
Original Message:
Sent: Jul 11, 2024 03:58 AM
Hi All
Customer requested for Airwave Architecture design diagram with respect to OS ,DB and Airwave Application layers. Appreciate your support for the same.
