Cloud Managed Networks
Airwave Clustering
This thread has been viewed 21 times
  • 1.  Airwave Clustering
    Posted Nov 18, 2021 11:17 PM
    Dears
    I want to make airwave clustering but I didn't find it in gui after research I just found that ( if I have three amp one of them will be as conductor (that means can't discover devices manually or automatically) and the rest will be the nodes to the conductor) . No other way though?
    Another question : want to know when to use the Awms-failover license .
    Thanks in advance
    Amr Abo Hashima
  • 2.  RE: Airwave Clustering
    Posted Nov 19, 2021 05:17 AM
    There is no clustering in Airwave. There are multiple redundancy options, which are all failover. And you can put Airwave Glass on top of it to get a consolidated view, which comes closest to clustering.
    Central-on-prem or Central may be a good alternative as well.
    Please reach out to your local Aruba partner or Aruba sales team to discuss your requirements and find the best match in your situation.
