Network Management
  • 1.  Airwave config job for multiple switch
    Posted Sep 11, 2024 10:58 PM
    How can I execute config job for multiple switch at the same time?
    Best Regards,
    Jackson Ku
    Jackson Ku
  • 2.  RE: Airwave config job for multiple switch
    Posted Sep 12, 2024 02:01 AM
    On Groups / Config & Audit Jobs create a job, select or create appropriate snippets or just type required commands, select switches and run job.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 3.  RE: Airwave config job for multiple switch
    Posted Sep 15, 2024 08:54 PM
    At Airwave may I execute some show command and collect the result for multiple switches at the same time?
    Best Regards,
    Jackson Ku
    Jackson Ku
  • 4.  RE: Airwave config job for multiple switch
    Posted Sep 23, 2024 10:20 AM
    You can. Same procedure as before. You will just need to check each device log separately to see the result.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
