Is there a cert chain and the entire chain uploaded to the server? Some self signed certs are not acceptable by some browsers depending on the Org security. No Certificate means the browser is not accepting the CA. Either the self signed is not recognized by your browser or not recognizing the root CA of CSR certificate. Is the issue same in incognito mode?
Regards
Gowri Amujuri
Original Message:
Sent: Mar 04, 2025 03:56 AM
Subject: Airwave ECDSA selfsigned not working
We are using Airwave 8.3.0.4 and try to set up ECSDA Certificates for the Web UI
No matter if we sign the csr and install the certificate via cli nor if we using self signed ECDSA the Web UI is not access able any more with browser error no certificate
